0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | well your pictures are alittle too dark for me to see if your missing anything
1937 1/2 ton
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what Dan said, but you are missing an air cleaner  Bill | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | It was hard to see but as far as I could tell I don't see anything missing except the air cleaner, as Bill already mentioned. Take some photos in the daylight and we can take a better look.
It looks like you have something decent to start with. BTW, the floor start is original. | | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | Thank you guys until I get some help lifting the hood off and moving it to the other side of the garage that's the best I can get because when open the hood blocks my lights
In an attempt to make myself sound like a bigger idiot does the air filter goes on top of the carb? | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Yes, it does go on top of the carb. If you don't have one, it would be good to get a Shop Manual. That will be helpful in doing repairs. An Assembly Manual is also helpful in showing how your truck goes together. You can easily buy reprints of each, and the Shop Manual is available electronically. Samantha | | |
