4 members (GradyB, J Lucas, pauld, klhansen), 206 guests, and 4 robots.
Topics128,204
Posts1,057,289
Members48,467
#504333 02/10/2009 5:52 PM
I recently acquired a replacement wood frame for my 1933 chevy one-half ton pickup. Is there a recommended glue to use in its assembly? Thank you for your help.
Don't know what the restorers are using but I've built a few wooden (spruce) airplane wings and used Resorcinol glue, that can hold up to the weather and that is what all the old WWI and WWII wood structures were glued up with.
You might try a few wood forums like this or ones that are geared toward homebuilt aircraft. http://www.kayakforum.com/cgi-bin/Building/Archive50.pl/noframes/read/57958
The aircraft supply houses will have good wood glues for your purpose. Try here for a start. http://www.aircraftspruce.com/search/search.php and search for “glue” on their site.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
3M makes some really good stuff that I use with boats. the 3M 5200 is a great on it alows the wood to shrink and grow with out breaking the seal of the glue and it is very sturdy, as far as what is to be used with cars you got me beat but if your just looking for something to do the job that 3M 5200 is the stuff
1953 GMC 3/4-Ton Truck
Wanna know more about me heres my Myspace
I dunno,5200....It get's stiffer than 4000.I like to use the 400 on boat's,it's more flexable and easier to remove later if need be.Also I think Denny want's something that won't show in the seam's.5200 and 4000 are white. Just my thought's.Tom
In my experience with a '34 I had years ago, you don't want to use ANY glue in the joints, just screws. The wood frame needs to be able to flex just a little. If you try to glue it up solid it will probably sound like the 4th of July the first time you take it down the road with all those joints popping and splintering. There was no glue used at the factory that I am aware of.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Old Gold is correct. Glue will just cause problems.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Yup I Agree with the last 2 posts I would not use any glue ...the wood needs to be able to breath an do its thing.
an back in 33' best ya could prob. get as far as Chemistry for glue was ELMERS.
Tim
1952 Chevy Shortbed
Photos in Photobucket
