| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 28 New Guy | | New Guy Joined: Jul 2008 Posts: 28 | I have a 55.1 3100 that I'm preparing to restore and I believe it has a seized up 235 engine. I have found a guy who is going to sell me a running 55 235, but it is coming out of a car. Will this engine out of the car drop into my truck and be compatable with the existing mounting holes and transmission? | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I'm not an expert on this but I'm pretty sure it's an easy fit, the only thing is that if it came out of a car with an auto trans it will have hydraulic lifters, with a standard trans it will have solid lifters. The REAL experts will know for sure. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 55 1st will used the high mount water pump, 55 2nd and cars use the low mount pump. Every thing else should be fine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | My 46 3/4 ton has a 55 model 235 out of a car and its mounted up to the original front and rear mounts that came in the 3/4 ton. So I think it will fit in you 55 no problem since they use the same front mounts. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I just put a ’53 235 car engine in my ’41 3/4 ton. Everything fit including the stick shift flywheel, bell housing & trans. Only differences were the 235 exhaust outlet angled toward the back (I ended up using the 216 manifolds) and the pivot pin for the gas pedal bell crank was in a different spot on the block. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Yes,it will easily bolt in. If the car engine has the lower water pump, you can use an adapter plate and the water pump from your truck engine. You most likely will have to switch the plate that is bolted on the front of the block, as it may not be the correct one for a front engine mount - you can switch it with the one from your truck engine (that's what I did when I replaced my 54 3100's 235 with one from a 53 car with an auto transmission). Samantha | | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | The car motor will also have fiber timing gears which run quieter but are not as durable as the metal timing gears in a truck motor. This will, in no way. effect the way the motor fits.
Ray | | |
