4 members (J Lucas, Otto Skorzeny, Ponchogl, 1 invisible), 92 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#504200 02/10/2009 6:36 AM
I have a 55.1 3100 that I'm preparing to restore and I believe it has a seized up 235 engine. I have found a guy who is going to sell me a running 55 235, but it is coming out of a car. Will this engine out of the car drop into my truck and be compatable with the existing mounting holes and transmission?
homeradam #504208 02/10/2009 7:35 AM
I'm not an expert on this but I'm pretty sure it's an easy fit, the only thing is that if it came out of a car with an auto trans it will have hydraulic lifters, with a standard trans it will have solid lifters. The REAL experts will know for sure. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #504347 02/10/2009 6:27 PM
A 55 1st will used the high mount water pump, 55 2nd and cars use the low mount pump.
Every thing else should be fine.
My Blog
My 46 3/4 ton has a 55 model 235 out of a car and its mounted up to the original front and rear mounts that came in the 3/4 ton. So I think it will fit in you 55 no problem since they use the same front mounts.
I just put a ’53 235 car engine in my ’41 3/4 ton. Everything fit including the stick shift flywheel, bell housing & trans. Only differences were the 235 exhaust outlet angled toward the back (I ended up using the 216 manifolds) and the pivot pin for the gas pedal bell crank was in a different spot on the block.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #504619 02/11/2009 4:11 AM
S Online: Content
Yes,it will easily bolt in. If the car engine has the lower water pump, you can use an adapter plate and the water pump from your truck engine. You most likely will have to switch the plate that is bolted on the front of the block, as it may not be the correct one for a front engine mount - you can switch it with the one from your truck engine (that's what I did when I replaced my 54 3100's 235 with one from a 53 car with an auto transmission).
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Samantha #506210 02/15/2009 5:39 PM
The car motor will also have fiber timing gears which run quieter but are not as durable as the metal timing gears in a truck motor.
This will, in no way. effect the way the motor fits.
Ray
