| | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | I have a 1946 1 ton with a 216 c.i. engine and I'm in the middle of a frame off restoration. This is my first restore, so I am learning/ making mistakes as I go along. I am now at the point of assembling the engine, and I made the mistake of not marking the camshaft/crankshaft teeth where they meet. The factory camshaft timing mark is obvious (stamped circle in the tooth valley), but the crankshaft timing mark isn't so obvious. I can't find anything and I'm loosing sleep over this. There is a faint line on one of the crankshaft teeth and a few indents on another tooth, but nothing that looks like a stamped circle. Am I missing something? I could time out the two gears using the #1/ #6 method, but I'd like to avoid that if possible. Has anyone had this problem? HELP!!! Thanks.
1946 2 Ton Flatbed
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Every one I have ever seen had a nice round dimple in one of the teeth. Are you sure the crank geer is clean? | | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | The crank gear is clean and oil free. There are two dimples on one of the teeth, but is it a dimple I'm looking for or a stamped circle like the cam gear has?
1946 2 Ton Flatbed
