2 members (Hotrod Lincoln, Millenimech), 76 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#503098 02/07/2009 11:12 PM
Ok so I'm still dinking around with the door latch on my '61 apache and I figure I need to take the latch out, my problem is the screws are not cooperating even with penatraiting oil, should I use a plumbers torch to heat up the screws to get them out or is there another option?
todjob2000 #503119 02/08/2009 12:26 AM
todjob2000,
Whenever I head to a latch chore, I always take my impact screwdriver set. They are pretty inexpensive, have a good assortment of bits, and one good blast with a medium ballpein and the screw surrenders.
Stuart
#503151 02/08/2009 2:24 AM
Impact screwdriver works like a charm, at under $40.00 everyone should own one.
hayhauler71 #503304 02/08/2009 10:48 AM
I always use my impact screwdriver when I know the screw has been there for more than a year or two- it usually means the difference between having to replace the screw or not (or getting it out or not). The impact keeps the phillips blade from slipping and messing up the head.
Paint & Body Shop moderator
4ontheFloor #503332 02/08/2009 2:55 PM
Ditto on the impact driver.Mine has saved me many times over the years.I dont know what they cost today,but I bought mine about forty years ago for under $20.And it has a special place in my tool chest.
dale937 #503376 02/08/2009 5:49 PM
Ok, Thank you again for the info, you guys are really helping me a lot.
