8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Ok so I'm still dinking around with the door latch on my '61 apache and I figure I need to take the latch out, my problem is the screws are not cooperating even with penatraiting oil, should I use a plumbers torch to heat up the screws to get them out or is there another option?
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | todjob2000,
Whenever I head to a latch chore, I always take my impact screwdriver set. They are pretty inexpensive, have a good assortment of bits, and one good blast with a medium ballpein and the screw surrenders.
Stuart
| | | | | Joined: Jan 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 47 | Impact screwdriver works like a charm, at under $40.00 everyone should own one. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I always use my impact screwdriver when I know the screw has been there for more than a year or two- it usually means the difference between having to replace the screw or not (or getting it out or not). The impact keeps the phillips blade from slipping and messing up the head.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Ditto on the impact driver.Mine has saved me many times over the years.I dont know what they cost today,but I bought mine about forty years ago for under $20.And it has a special place in my tool chest. | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Ok, Thank you again for the info, you guys are really helping me a lot. | | |
