1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#502867 02/07/2009 6:08 AM
I'm taking off the cab on my old 53 1 ton. While removing the old wiring I thought this wiring seems good , wonder if I should replace it. I'm going to have the cab painted. I'm not going after a show truck but I don't want it to burn up either. I would like some input on this. Thanks in advance!
Funton #502874 02/07/2009 6:30 AM
Just my 2 pennies, but if ya have it all out anyway this would be the time to upgrade to a modern fuseblock, and having "fresh" wiring NEVER HURT any older vehicle.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Hi Funton, for the extra few bucks,it's peace of mind.
Sounds like your quite far in anyway and as Tim already said,a modern fuse block will protect your investment!
Good luck
Jock
More pix on Flickr.
if it dosent snap when you bend it then its fine if it dose snap then you will have bare wire thats when its time to change it after i pulled all the wires going no place out of my truck the wiring left was fine
two things
1. usually just the exposed ends, (about 6-8'' ) get bad on old wiring. if it ain't broke ........... .
2. old wiring only does what the PO or factory wanted it to do. because we now live in a time where we want more... maybe it's time to add another function if you need to.
Jim & Caroline
After coming close to burning up my '63 C10 Fleetside due to bad wiring that seemed good, I say replace it while you can. It only takes one bad wire to ruin your day, and since you have everything out you might as well spend the extra for a new electrical system. That's my .02 anyway.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
When I restored My 52, even though the wiring appeared good, I replaced it anyways...Also, replaced it with the original woven
type wiring...being that the original wiring was more than 50 years old, surely somewhere there was a bad wire...Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Bill_B #504557 02/11/2009 2:23 AM
I think replacing the wiring is a good idea. I didn't, I coated the last six or eight inches of all the wires with liquid electrical tape. I was amazed to find that the original wiring on my '50, was tinned full length. Just another reason I like my truck. I do agree with Bill B, though, cloth covered wire looks right in my opinion. But does cost more...
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
