| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50312 09/19/2005 2:35 AM | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | When adjusting the float level with a spring float needle, do you take the measurement with the float resting on the spring or do you compress the spring until the float stops?
Thanks!
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
#50313 09/19/2005 1:33 PM | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | With the spring loaded fuel valve ALWAYS take the measurement with the float resting on the spring. DO NOT compress the spring.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#50314 09/19/2005 7:10 PM | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | Thanks Jon! That's what I thought, but I wanted to make sure.
Charlie
