0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#50312 09/19/2005 2:35 AM
When adjusting the float level with a spring float needle, do you take the measurement with the float resting on the spring or do you compress the spring until the float stops?
Thanks!
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
Carburetion specialist
With the spring loaded fuel valve ALWAYS take the measurement with the float resting on the spring. DO NOT compress the spring.
Jon.
The Carburetor Shop
Thanks Jon! That's what I thought, but I wanted to make sure.
Charlie
