| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | I'm taking off the cab on my old 53 1 ton. While removing the old wiring I thought this wiring seems good , wonder if I should replace it. I'm going to have the cab painted. I'm not going after a show truck but I don't want it to burn up either. I would like some input on this. Thanks in advance! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Just my 2 pennies, but if ya have it all out anyway this would be the time to upgrade to a modern fuseblock, and having "fresh" wiring NEVER HURT any older vehicle. Tim | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Funton, for the extra few bucks,it's peace of mind.
Sounds like your quite far in anyway and as Tim already said,a modern fuse block will protect your investment!
Good luck
Jock 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | if it dosent snap when you bend it then its fine if it dose snap then you will have bare wire thats when its time to change it after i pulled all the wires going no place out of my truck the wiring left was fine | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | two things 1. usually just the exposed ends, (about 6-8'' ) get bad on old wiring. if it ain't broke ........... . 2. old wiring only does what the PO or factory wanted it to do. because we now live in a time where we want more... maybe it's time to add another function if you need to.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | After coming close to burning up my '63 C10 Fleetside due to bad wiring that seemed good, I say replace it while you can. It only takes one bad wire to ruin your day, and since you have everything out you might as well spend the extra for a new electrical system. That's my .02 anyway.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | When I restored My 52, even though the wiring appeared good, I replaced it anyways...Also, replaced it with the original woven type wiring...being that the original wiring was more than 50 years old, surely somewhere there was a bad wire...Bill B. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I think replacing the wiring is a good idea. I didn't, I coated the last six or eight inches of all the wires with liquid electrical tape. I was amazed to find that the original wiring on my '50, was tinned full length. Just another reason I like my truck. I do agree with Bill B, though, cloth covered wire looks right in my opinion. But does cost more... | | |
