9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55),
156
0
Mod | | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | looks like i have to have the old shoes relined,unless there is a source someone knows of for 1 52 3800 rears are 21/2x15 fronts are 2x12 this is the huck style i am told, thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy trying, Jim Carter has the shoes that you are looking for I believe, I think the size of your rear shoes is actually 2 1/2" X 14", not 15", p/ns are, rear MEB514 $84.75 + $75.00 core, if you send them your rebuildable shoes you get the core back, front ME1431 $84.75 + $75.00 core, I believe those prices are per axle, but you should call and confirm, Jim Carter's phone number is 1-800-872-1913, hope that helps | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I'd just go to a commercial truck or brake shop and have them relined for a bunch less.
Bruce | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you buy replacements and send your old ones in as cores, you better hope that they are correct. I opted to have mine redone.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 |
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
