7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | I'm trying to come up with an approx. weight for a single axle C80 tractor (1965) with a 409, 5spd., 18500 lb. axle, 5th wheel, cast spoke 10x20, 50 gal fuel. Anybody have one with a known empty weight? I'm guessing around 8500 lbs. Appreciate the help!
James | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Just asked a friend who owns a 65 C80 single axle tractor. His estimate was 10,500. | | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | I appreciate the info, your weight sounds more accurate than my number. I would like to find a nice, clean '64 or '65 C80 single axle tractor with the specs mentioned above for sale. Thanks Again! JAMES | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I had the 1960 L80 Chevy Tractor I owned weighed once. It was equipped with 348 engine, 5 spd. trans, two spd. rear axle, with a 18500lb. rear axle. It also had a saddle tank with sanders. I can't remember exactly what it weighed, but it was somewhere between 6500lbs., & 7500lbs. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Not a real good comparison, but it might help. My '62 GMC 4000, 305 V-6, 4-Speed, Budd Wheels, 16 Ft Wooden Flatbed with a GVW of 19,500 weighed 8000 lbs. My '62 GMC 6500, 478 V-6, 5-Speed, 2-Speed, Air Brakes, Spoke Wheels, 50 Gal Tank, 16 Ft Steel Flatbed Dump with a GVW of 32,000 lbs weighed about 12,500 lbs.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
