8 members (Donf, tclederman, C10 - C90 Bill, HandyAndy, DoubleB, Otto Skorzeny, Gdads51, 1 invisible), 44 guests, and 1 robot.
Topics128,090
Posts1,056,020
Members48,430
#502575 02/06/2009 5:36 PM
After the distributor is removed so I can prime the oil pump with a drill, can I just put the distributor back in or do I have to go through the process of bringing #1 to TDC before replacing it? Thanks
watsjoe #502637 02/06/2009 7:59 PM
As long as you mark where the distributor was before you removed it you should be able to just drop it back in.
Paint & Body Shop moderator
True...but you will have to use your long screwdriver to align the oil pump slot so the distributor will drop back in all the way to the marked position.
Stuart
