Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#502060 02/05/2009 4:36 AM
I have two Rochester carbs that are manual choke on a Fenton intake. Problem is the carbs are at a right angle to the pull cable for the choke. Anyone have a setup that can solve this problem so that i can use my choke cable? I hope i have made it clear as to what the problem is. Cecil.......
maybe something adapted from the hand throttle setup? like pic here
Cecil,
I haven't addressed this problem, so this might be bad info. I have linked a site with good close-up pictures of a Rochester and its cable arrangement. Your application uses two carbs, and probably one choke so the setup should be the same.
The only stumbling block I can see would be a air cleaner that gets in the way of the cable.
I hope this helps.
http://community.webshots.com/album/127846177Netwnl
Stuart
