| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I have two Rochester carbs that are manual choke on a Fenton intake. Problem is the carbs are at a right angle to the pull cable for the choke. Anyone have a setup that can solve this problem so that i can use my choke cable? I hope i have made it clear as to what the problem is. Cecil....... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe something adapted from the hand throttle setup? like pic hereBill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Cecil, I haven't addressed this problem, so this might be bad info. I have linked a site with good close-up pictures of a Rochester and its cable arrangement. Your application uses two carbs, and probably one choke so the setup should be the same. The only stumbling block I can see would be a air cleaner that gets in the way of the cable. I hope this helps. http://community.webshots.com/album/127846177NetwnlStuart | | |
