| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | Can anyone confirm if the motor mounts for an LT1 are the same as a standard 350? The folks at CPP seem to think they are but they could not confirm.
Thanks all. | | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "The LT engine uses a new engine block, cylinder head, timing cover, water pump, intake manifold and accessory brackets. On the other hand, the engine mounts and bell housing bolt pattern remain the same, so the newer engine can readily be swapped into an older vehicle" - from hereBill | | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | Thanks Bill......I really appreciate the feedback.
| | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Is there a particular reason you are looking at using the LT1? I have a 96 Z28 with an LT1 and it is THE worst 350 ever made, more specifically because of the optispark distributor. My car has around 140K on it and it is having all sorts of ignition issues, oil leaks etc and the car has been babied and they are mostly highway miles. So if you are still on the fence I would recommend another engine choice if at all possible. There are some really affordable LS1s out there from older trucks, they are a great powerplant and they have coil packs  just my 2cents worth | | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | The LT1 is a good choice. I have one in my 34 Ford and my 96 Impala has the 350 LT1. It has 265,000 plus miles on it runs great and uses on oil. | | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Wow...glad to hear that! I hang out at the Z28 bulletin boards frequently and your story seems to be the exception and not the rule. Case in point, seems I will be working on it again this weekend as something is wrong with the wiring harness or something because it just blew another $168 ICM.... | | | | | Joined: Oct 2007 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 102 | 28 Chevys & 64C10,
I cannot confirm one way or the other that this LT1 / 4L60E tranny combo I've purchased was a wise decision in any case. I do know the previous owner and understand the modifications done to the wiring harness to simplify it. I wanted "driveability" not major horsepower or old school inefficiencies. I know....there are plenty of options out there, 283, 327, 350 etc. I got a good buy, I knew its history, I like the statistics and it fit well. If this ends up a bad choice, I will mark it up with all the others I've made over the years including buying this "rust bucket" to begin with. HA It's always good to read the feedback, but generally, the pendulum swings pretty hard between old school and newer technology.
Thanks again fellas.....I will keep you posted on how this project progresses and I certainly will "complain" openly if this LT1 comes back to bite me!
NorthDM | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The LT1 is a Generation 2 SBC. The only main difference is the reversed cooling. The engine mounting bosses are in the same location.
