0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | I have a 64 C10 and I would like to know if its possible to take a used powerbrake booster and master cylinder from another 70's truck/van with 4 drum brakes and install it on my truck? I am trying to save money so I was going to go to a junk yard and buy a good used set and fab my own braket possibly(?) Has anyone done this, would you recommend it? Thanks in advance for everyone's help. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Are there not any old trucks in your local junkyards? Check to see if they have a Hollander Interchange manual. That will tell you what will bolt in. Your master cylinder will work with or without a power booster. As long as you're making changes it would be wise to step up to a dual chamber master cylinder from a drum brake truck 1967 or later.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | Thanks Devin! Unfortunately the junkyard here is ecology and they dont have the hollander manual. I was definitely planning on going with the dual chamber one but one thing that I have been curious about is that I have seen other 64 C10 with the power master cylinder setup and the bracket that holds it to the firewall is huge! in the sense that it appears to keep it about 7 inches from the firewall, I have been wondering why that is. | | |
