1 members (52Carl), 98 guests, and 2 robots.
Topics128,127
Posts1,056,677
Members48,452
I was just wondering if anybody had any tips about making sure idle and mixture are correct on this set up...
TIA
Fred
52 3600
69 C-10
thanks...that looks informative...not sure how that figures into mixture adjustment tho..
would pulling the plugs for inspection help?
not sure if the weak rings in my eng would mess up this means of investigation?
Mike
Tune for maximum vacuum. I usually set the idle as low as it will go, then set the mixture. Do it again until your changes are minimal. I then bump the idle up just a bit so it doesn't die at stop signs. With automatic tranny and a/c, they need to be engaged when you reset the idle at the end.
Pulling the plugs won't hurt, that's for certain.
http://www.theultralightplace.com/sparkplugs.htm
Fred
52 3600
69 C-10
Riding in the Passing Lane
Without hi tech equipment a good way to tell if the main mixture is about right is with the choke open it should hesitate & bog when the engine is cold. Than run good after it warms up. To set the idle mixture turn the idle mixture screw in slowly till the engine starts to slow down. Then back it out till it runs good about 1/2 turn. Reading the plugs is also good. If the porcelan is black it shure is rich. If there is a little soot on the shell it,s a little rich.
1972 Chevy c10 Cheyenne Super
thanks guys,I'll make some mixture adjustments and the pull the plugs after running the truck a little...see what it will tell me...
