1 members (68ironhead),
89
Mod | | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50193 09/15/2005 5:17 AM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | I was just wondering if anybody had any tips about making sure idle and mixture are correct on this set up...
TIA | | |
#50194 09/16/2005 4:36 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 |
Fred 52 3600 69 C-10
#50195 09/16/2005 6:11 PM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | thanks...that looks informative...not sure how that figures into mixture adjustment tho..
would pulling the plugs for inspection help?
not sure if the weak rings in my eng would mess up this means of investigation?
Mike | | |
#50196 09/16/2005 8:35 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Tune for maximum vacuum. I usually set the idle as low as it will go, then set the mixture. Do it again until your changes are minimal. I then bump the idle up just a bit so it doesn't die at stop signs. With automatic tranny and a/c, they need to be engaged when you reset the idle at the end. Pulling the plugs won't hurt, that's for certain. http://www.theultralightplace.com/sparkplugs.htm
#50197 09/16/2005 10:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Without hi tech equipment a good way to tell if the main mixture is about right is with the choke open it should hesitate & bog when the engine is cold. Than run good after it warms up. To set the idle mixture turn the idle mixture screw in slowly till the engine starts to slow down. Then back it out till it runs good about 1/2 turn. Reading the plugs is also good. If the porcelan is black it shure is rich. If there is a little soot on the shell it,s a little rich. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50198 09/17/2005 3:29 AM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | thanks guys,I'll make some mixture adjustments and the pull the plugs after running the truck a little...see what it will tell me... | | |
