4 members (Otto Skorzeny, Samantha, Jon G, cmayna), 112 guests, and 2 robots.
Topics128,071
Posts1,055,901
Members48,429
Years back I re-wired my stock 49 using connectors, wires and the schematic in the shop manual. I went wire to wire and it was pretty simple and works perfectly. Now I am thinking of going with one of the big name harness kits because my ignition and headlight switches are getting old and I really don't like the squirrel's nest of wires under the fuse box. It would be nice to have new components like switches and real fuses.
Maybe I have a mental block but when I read how easy it is to install one I these kits I start asking myself questions and the one which comes to mind is how does the juice get to the new fuse box? I know its a dumb question but I assume it comes from the same source as the original. And with my add-on turn signals will I have to do some complicated rewiring?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Blu,
On my Ron Francis kit the main power lead from the starter to the fuse panel was included along with the 1 wire alternator set up wich I requested.
Every wire was included in the kit along with new headlight plugs and a connector to hook to a 70's chevy steering column including the brake light switch.
Best thing I did was call there customer service an told them exactly what i wanted to do and what steering column, alternator and stuff like that I was using and had NO PROBS.
Everything was in the kit.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Thanks Tim. This truck is all stock except for the turn signals and a 12 volt system. I do not plan on changing the steering column and was hoping the brake light switch and turn signal wiring in a kit would take that into consideration.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I agree with SW-Radial. I installed a Ron Francis harness and it was a snap! Their tech assistance is top notch if you have any problems. I had never done anything like that before and everything works. I had also told them everything I wanted to do and they made the kit.
I also agree with fasteddie, the customer service dept. at Ron Francis is TOP NOTCH!
Tim
1952 Chevy Shortbed
However does anyone know of a company that would replicate the original wiring in a 49 without having to go to a later model column, alternator and does consider the aftermarket turn signals?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
As I understand it Painless and Ezwire both have model specific kits. Mine was from American Auto Wire and I choose the kit that allowed me to place the fuse panel wherever I wanted it. All wires were about 8 feet longer than needed. I would suggest this kit for anyone that wanted to customize their wiring.
~Jim
Ex Hall Monitor
Ex Hall Monitor
YNZ
Try Rhode Island Wiring Service. They make harness for the restorers. You can always build your own-- it ain't that hard if you just take your time.
I have done my own but years ago and now, as I wrote at the outset, I am concerned about the original switches and the mass of wires under the fusebox.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
