0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50181 09/14/2005 11:51 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Hi guyz, it's good to be back online again. I'm sure this has been hashed over so I'll do a check and search... But I'm gathering what I need to finish w/ the engine/drivetrain install. I'd like to put a quiet set of mufflers in this 3100 w/ a fairly stock 292. I have Langdon's split 3+3 headers and if my old memory serves me now I think he says NOT to install flowmasters. I think I've also heard they don't sound or work v-well w/ L6's, better for V8's, any. So what is a good muffler to use that's quiet. I believe I should run a crossover but I'm letting the mufflerman do that end of it. I also have a 500 edelbrock & clifford. I believe I should use 1.75'' pipe?? Another question is should the mufflers go closer to the engine or towards the axle?? Does that make a difference?? why?? Is there a way to have the two mufflers come out of one pipe right at the end. I really love the sleeper look. I don't really know what ''a classic sound'' or ''rap-rap'' is that's used in advertising mufflers. Any insites guys?? thanks for the help.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#50182 09/15/2005 12:31 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you want to keep the Chevy six rap-rap sound, don't use a crossover. The closer the mufflers are to the rear the less cab noise you have, and they usually stay cooler and will last longer. I like the sound of Dynomax Super Turbos, not as loud as the flowmasters, but louder than stock. If you want quiet, you need to go with a stock Walker muffler. A good exhaust man will be able to answer a lot of the questions you have.
Fred 52 3600 69 C-10
#50183 09/15/2005 3:23 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | OK Let me ask this... who has a 292 and what muffler do you run under your truck and how do you like it dual or single exhaust tailpipes??? do you run a crossover??
#50184 09/16/2005 6:22 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | On my '65, I'm using long tube headers with 1.75 pipes all the way out to the bumper. I've got 24" glasspacks under the bed, just forward of the coil springs. No x-over, just straight pipes coming off the headers. Normal driving isn't loud but, if I romp on the accelerator it gets pretty loud. I actually love the sound when the secondaries open up . I have a hard time staying off the gas 'cause it sounds cool which of course gets expensive. If you want all quiet, all the time then yeah, look into the Walker: quiet mufflers -David | | |
#50185 09/16/2005 9:58 PM | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | I prefer the huge walker mufflers on my 292 because I frequently pull a stock trailer through the mountains with lots of third gear and I like it quieter. Jim | | |
#50186 09/17/2005 1:14 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Originally posted by carolines truck: OK Let me ask this... who has a 292 and what muffler do you run under your truck and how do you like it dual or single exhaust tailpipes??? do you run a crossover?? caroline, You're a relative newcomer and were not around the 2 or 3 years ago when I built my 292 (and bothered everybody here darn near to death!  ) I have my engine in a 1966 shortbed stepside pickup and run the extra long 36 inch tube headers. The exhaust is joined together about a foot past the 2 1/2 inch header collectors by a makeshift welded "Y" pipe. The single pipe is 3 inches in diameter and goes into a single-in/dual-out FlowMaster 40 series muffler. I like the results and look forward to doing a similar setup on my next engine. Only thing I'll do differently next time is use a smaller diameter muffler inlet (maybe 2 1/2 inches instead of 3 inches). The sound is different for a straight 6 (Woogeroo has heard it). Not a typical 6 cylinder sound at all. Most people think it's a stock small block. The exhaust note gets slightly raspy when you punch it really hard and hold it. On normal acceleration the exhaust stays deep and low. Just like I want it. -ftyler | | |
