6 members (Gdads51, Joe H, Otto Skorzeny, 1955 1 Series, cmayna, 1 invisible), 102 guests, and 2 robots.
Topics128,193
Posts1,057,249
Members48,466
Hi guyz, it's good to be back online again.
I'm sure this has been hashed over so I'll do a check and search...
But
I'm gathering what I need to finish w/ the engine/drivetrain install. I'd like to put a quiet set of mufflers in this 3100 w/ a fairly stock 292. I have Langdon's split 3+3 headers and if my old memory serves me now I think he says NOT to install flowmasters. I think I've also heard they don't sound or work v-well w/ L6's, better for V8's, any. So what is a good muffler to use that's quiet. I believe I should run a crossover but I'm letting the mufflerman do that end of it. I also have a 500 edelbrock & clifford. I believe I should use 1.75'' pipe?? Another question is should the mufflers go closer to the engine or towards the axle?? Does that make a difference?? why?? Is there a way to have the two mufflers come out of one pipe right at the end. I really love the sleeper look. I don't really know what ''a classic sound'' or ''rap-rap'' is that's used in advertising mufflers. Any insites guys??
thanks for the help.
Jim & Caroline
If you want to keep the Chevy six rap-rap sound, don't use a crossover. The closer the mufflers are to the rear the less cab noise you have, and they usually stay cooler and will last longer. I like the sound of Dynomax Super Turbos, not as loud as the flowmasters, but louder than stock. If you want quiet, you need to go with a stock Walker muffler. A good exhaust man will be able to answer a lot of the questions you have.
Fred
52 3600
69 C-10
OK
Let me ask this... who has a 292 and what muffler do you run under your truck and how do you like it
dual or single exhaust tailpipes???
do you run a crossover??
Jim & Caroline
On my '65, I'm using long tube headers with 1.75 pipes all the way out to the bumper. I've got 24" glasspacks under the bed, just forward of the coil springs. No x-over, just straight pipes coming off the headers. Normal driving isn't loud but, if I romp on the accelerator it gets pretty loud. I actually love the sound when the secondaries open up . I have a hard time staying off the gas 'cause it sounds cool which of course gets expensive.
If you want all quiet, all the time then yeah, look into the Walker: quiet mufflers
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
I prefer the huge walker mufflers on my 292 because I frequently pull a stock trailer through the mountains with lots of third gear and I like it quieter. Jim
Quote
Originally posted by carolines truck:
OK
caroline,
You're a relative newcomer and were not around the 2 or 3 years ago when I built my 292 (and bothered everybody here darn near to death! smile ) I have my engine in a 1966 shortbed stepside pickup and run the extra long 36 inch tube headers. The exhaust is joined together about a foot past the 2 1/2 inch header collectors by a makeshift welded "Y" pipe. The single pipe is 3 inches in diameter and goes into a single-in/dual-out FlowMaster 40 series muffler.
I like the results and look forward to doing a similar setup on my next engine. Only thing I'll do differently next time is use a smaller diameter muffler inlet (maybe 2 1/2 inches instead of 3 inches). The sound is different for a straight 6 (Woogeroo has heard it). Not a typical 6 cylinder sound at all. Most people think it's a stock small block. The exhaust note gets slightly raspy when you punch it really hard and hold it. On normal acceleration the exhaust stays deep and low. Just like I want it.
-ftyler
