7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
#501482 02/03/2009 10:07 PM
I am just doing some research and I am looking thru Patricks catalog for the Torque Tube tranny swap... you supply the tranny. So what is the core charge for main shaft? Do you have to swap out the main shaft on the saginaw tranny you supply? I have a '49 GMC 1/2 ton 4 speed . This swap should be easy enough but I am trying to get it all together before I buy anything. then I read that the saginaw linkage will interfere with the brake power booster if you mount it down there. but other guys make minor adj. to the brake lines and it all works. so does any body have a paper or a write up on this? other than what i have read what about patricks SS exhaust. Does the power booster interfere with that?
1949 GMC FC102 4 speed
1970 Corvette t-top 350 350hp 4 speed
1997 Chevy Suburban 1500 4x4
1999 Saturn SC1
Bolter#17856
Call out to Patricks and ask for Patrick or his son. They can answer all your questions. 520 836 1117
