6 members (55shaker, Uncles51, GRNHydra, Ponchogl, JW51, Forty9), 55 guests, and 5 robots.
Topics128,021
Posts1,055,349
Members48,420
#501325 02/03/2009 8:18 AM
on my 52 isnt there a pin on the side you push in and the shaft will pull out im pushing it but shaft isnt coming out thanks for any help
32fire2 #501355 02/03/2009 1:42 PM
These two pictures show the inside of the light switch and how the button releases the shaft. Should help you get a feel for what’s happening to prevent it from releasing. Some times you have to find the sweet spot where the button is not quite pushed in all the way. http://rides.webshots.com/photo/2934212090098611668uCqyRR http://rides.webshots.com/photo/2823523620098611668svjVkt
Check your PM's
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I agree with Denny. Sometimes you have to wiggle the shaft a little, or push it in slightly to release the latch.
Harvester
Harvester #501491 02/03/2009 10:27 PM
Riding in the Passing Lane
Pull the knob out to the on position first. Sometimes a little WD 40 or equivilent helps.
1972 Chevy c10 Cheyenne Super
Thanks George, I forgot to mention that, kinda helps to have the knob pulled out all the way.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Also the shaft on the originals has a flat spot on some years (52 & 50) that I have experience with. Put that flat spot to match the pin and it usually comes out a little easier.
