1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | I have a 1936 Chevy truck and I have a friend that has a 1937 and a 1938, he is going to build the 1938 so he don't need the 1937 frame I don't have a frame for my truck, SO would the 1937 frame work under my 1936 truck ? Thanks all
frankenstein Fabrications
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Is yours a tall cab or short cab like the '37? I think that would make a difference. Joe | | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | What is the tall cab or short cab ?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They made a midyear change in 36 like in 55. The high cab was like the 35 & the low cab was like a 37. I dont know how to tell the difference off hand but some of the fellow bolters will jump in. My partner & I are restoring his 36 low cab fuel truck. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I talked to my partner on this. The interchange book shows 36 by itself. 37 & 38 are the same. That is 1/2 ton trucks. The high cab has 3 door hinges & the low cab has 2. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Both trucks have a 112 inch wheelbase so there is a chance that the 37 frame might work for a 36. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | Let me help here.
I own a 34 and 35 which are called High cabs and they offically went to mid 36 but, at the same time the 36 Low cab came out.
One way to tell the diff. Other than the overall design is this.
The cab from 34-36 High cab. : The cowel,A pillars,Roof and Rear/Back of the cab are in many Parts.
The 36 Low cab Cowel to the roof to the rear of the cab are all On Solid piece. and is just a little shorter.
There is very little wood in the 36 Low Cab and Do Not Use the doors for an example. The High Cab Doors lost all their wood and became Metal. So, Only refer to the wood.
Now, If you Figure you Do Have the High Cab.
You Can Use the 35/36 Chassis. the late to 36 chassis has hydrolic brakes and will fit your truck.
I hope this helps... Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
