6 members (klhansen, mk72, Guitplayer, cmayna, 5 Window 9434, 1 invisible), 64 guests, and 2 robots.
Topics128,053
Posts1,055,776
#445436 08/25/2008 4:04 AM
Does anyone know if somebody reproduces the glass for the clamshell door on the 47-54 subs? Or do I need to find a good original? Thanks!
Hi, First of all welcome to the 'bolt!
I'm not too familiar with the clamshell door but I will assume the glass is flat.
If so any competent glass shop should be able to cut one for you using laminated glass. If you prefered tempered glass they should be able to get one made for you.
Maybe someone will chime in and confirm if the glass is flat or not.
Good luck with your project.
Jock
More pix on Flickr.
I
I Offline
Patina, I have a back glass for the clamshell doors, happeened to get two with my '49 when I bought it. I crated them up and stashed them in the attic. Everyone says the clam doors are the ones to have, I personally like the looks of the barn doors. Inuke
'49 Sub, '49 Fleetline
1952 GMC Suburban
1949 Chevy Suburban
1949 Chevy Fleetline
Stories in the Gallery
More pix on Photobucket
Bowtiebits carries backglass for the clamshells. That's the only place I've seen that claims to have reproduction of that piece. http://www.bowtiebits.com/store/sto...amp;Category_ID=2&Sub_Category_ID=28
By the way, Inuke, you do you still have any of those pieces of glass. I might be interested depending on the shipping cost.
52 suburban rat rod. 350/350, 9-inch ford rear, independent suspension with 2-inch drop spindles, power rack, two-tone Mexican blanket interior, paint by mother nature
50patina could I get a picture of the hinges for the top part of the clam shell. I can't seem to find them anywhere and would like to know what they even look like. Thanks
I've got a glass for a clam shell and it's definitely not flat. It is curved.
38 original
48 panel
59 stepside
46 in the back forty
I stand corrected Highwayman....I assumed the glass was flat.
Ya live and learn! thumbs_up
More pix on Flickr.
48burban,I tried to get some pics of the upper hinges.My first time putting pics on here so someone let me know if it works. Also philburban thanks for the link to bowtiebits.I hadn't heard of them before,that looks like my best option if I want new.
http://picasaweb.google.com/stierwaltfarms/50Suburban?feat=directlink
They worked, but you got some butt ugly hinges. eeeek I took a picture of my hinges today so that I could post, but they are bad as yours! This is typical of many of the clamshell hinges that I have seen. I plan on doing a little fabrication to both the frame and hinge. Thanks for posting!
thanks for the pics guys
