| | | Forums66 Topics128,094 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Anyone know where I can get head bolts for my 54 235, specifically head bolt studs. Im working on putting a power steering pump on my 54 235 and need to change out the first two head bolts on the driver side of the head to studs. The alternator is being moved up high and my plan is to have the bracket bolt up using studs.
My last resort is to weld a bolt on top of the head bolt, but Im hoping that isn't going to be needed.
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Some of the 235's in the early 60's with power steering had what your looking for; you might try Jim Carters. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | thanks, looked but didn't see any | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | There is a set of head bolts on e-bay item # 220352131971.Says for 216/235
mo2cyl Kevin
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I got to tell You it is never a good idea to use head bolts to bolt things down , better idea to weld bolt to top of head bolt,if You cannot find a better way to install power stearing pump they do not even put lock washers on head bolts because of the hot and cold stress on the bolts. Pete | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Im not bolting the bracket down with the head, meaning putting the bolt through the bracket and head and then tightening it down. I know not to do that. I may just end up trying to weld a bolt onto the top of the two head bolts I have. I can't seem to find any online. I guess you can call what Im looking for a stud. Its just a regualar head bolt (so the nut is fixed) with thread on both sides. Im not looking for a threaded rod with a nut that I tighten down. ToddM has what Im talking about https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=495732#Post495732 click link to engine 3
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I will look on My 216 tommorow and see if theres one on that I can also ask My son in law He owns a auto repair shop and rebuilds alot of engines. Get back to You tommorow. Pete | | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | It looks alot like some exhaust manifold bolt/stud on v8s.Maybe your local flaps might be able to find one the right length and grade. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The old (5.7) 350 Oldsmobile diesel engines found in the Oldsmobiles, the Cadillacs and the Chevrolet trucks had head bolts like you need. The General Motors part number is number: Gr. (Group) 0.293 Part Number 022520637. This is actually a 3 inch long head bolt with a stud on top from the diesel engine that will work as a head bolt on a 216-235-261 head. You might check with a parts counter at one of those General Motors dealerships. I used them on my 261. The wrench size is one size larger, but they work perfectly. Good luck! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hi, asked My son in law He said You can get them from a auto parts store like NAPA , or from chevy parts dept. I hope this helps , Pete | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Napa didn't really have anything for me, and if they did Id have to buy them as a kit which I don't need. Now that I think about it he might not have understood me completely or I didn't explain what I was looking for. I brought in one of the head bolt from my truck, I think he thought I was looking for a regualar head bolt and not a stud.
Anyways I ended up finding what I needed after all and I already had it. A few days ago I stopped at the local auto yard to see if any GM 250 inlines had the studs, but didn't find any. I decided to check out the Jeep inline 6. To my surprise all it had was studs and even better they were the same diameter as the original (1/2"). When I brought them home and compared them, the Jeep bolt was about a inch longer, but the length from the hex head to the start of the threads was the same as the one from mine. Cut the extra inch off from the Jeep bolt and I had what I was after. I had compared the bolts a few days ago and for some reason thought it was different and couldn't be used. The stud on top is smaller as it is a 7/16".
| | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Call ARP and simply have the lenght and thread handy.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Glad it worked out for You, Pete | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I tried ARP about 3 years ago and they didn't have them, at that time anyway. This question has come up before and I can tell you from personal experience that new inline headbolts are really hard to come by.
I'd like to see one of you enterprising young guys have someone make up a bunch to the proper specs and have them for sale. I think you'd sell them. A lot of the other engine bolts are available stainless and even Bowtie versions. I doubt you could retire on it but it would be fun and even generate a little profit. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | A few people told me I could of used Grade 8 bolts. The thread is 1/2"-13. The guy at napa matched the stock head bolt up to a Grade 8 bolt that was also the same length. Looks like it would of been usable.  | | |
