2 members (UtahYork, Nick in Manitou), 46 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#50095 09/13/2005 7:55 PM
Junior Member
Junior Member
What dose the e-brake cable connect to inside the brake drum. This is on a 54 3100 1/2. This was the first thing I did on this restoration 21/2 years ago and i just don"t remenber if I lost something or it was missing.
Thanks Manfighter 16
#50096 09/13/2005 8:08 PM
Anonymous
Unregistered
Anonymous
Unregistered
Typically the e-brake cable attaches to the bottom of the rear shoe on the inside surface. The cable also has a mounting flange that makes the connection to the back side of the backing plate.
#50097 09/15/2005 8:20 PM
Junior Member
Junior Member
Thanks Houston54, I think my is missing the spreader bar between front and back shoe. I would like to see a picture so I could find one or make
one.If any body has a picture it would help.
Manfighter16
#50098 09/15/2005 9:35 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have the assembly manual at the house which should have a pic of the brake shoe assembly. I will look tonight but also look out on the tech tip section of the bolt as I thought I had seen it there previously.
