| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | I realized that I need to replace 7 captive nuts for the door hinges on my cab but so far I can't seem to find a vendor that sells them. Is there anyone that makes replacement ones? I would have no problem welding nuts in as a replacement but I'm guessing that they were originally captive nuts to allow adjustment in the placement of the door hinges. Is this correct, or should I just weld nuts in?
Neil 1955 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen anything like cage nuts available, and it is handy to have them where they were originally used, but as much for locating and holding as for adjustment .... you could always try making your own cages
Bill | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I keep square nuts around for just that. If I need a cage nut, I stick a welding wire to a square nut, run a few more inches of wire out and cut it. Square nuts are pretty good about grabbing something to keep them from spinning. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Milhouse, Mar-K makes the lower door hinge repair panels and also can supply the cage nuts separately. This is the cage nut that is toward the door opening, not the bigger one on the firewall area. Ask for part number 110683 for the square cage nuts with cage. I think these are also the same for upper door hinge.
Mar-Ktech | | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | No kidding! I would have never guessed to check Mar-K, thanks! I just placed my order for them and look forward to installing them on my cab.
Thanks again!
