5 members (Steelonsteel, Hotrod Lincoln, 55shaker, ShopRag, 78buckshot), 100 guests, and 1 robot.
Topics128,035
Posts1,055,552
#50078 09/13/2005 3:39 AM
Apprentice
Apprentice
I have a 56 chevy with a broke axle. It is the original 10 bolt rear end. Can someone tell me where to get parts for it. I need the one axle, seals and bearings.
#50079 09/13/2005 3:48 AM
Any parts truck from the 50s and maybe earlier will work. Make sure you get the one from the same side. They are different lengths on the other side.
#50080 09/13/2005 10:07 PM
Riding in the Passing Lane
The seals & bearings can be purchased new at any parts store. They may not be in stock but they get shipments every day from the warehouse. Post an ad on the parts wanted. I,m shure many stovebolters have some old rear ends around.
1972 Chevy c10 Cheyenne Super
#50081 09/15/2005 4:32 PM
Apprentice
Apprentice
thanks for the help
#50082 09/15/2005 8:41 PM
kevint.... thier is a gentleman that lives in
Deford that probably has the parts You need ...If You want his contact info, email me and I will send it to You..
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#50083 09/16/2005 2:39 AM
Apprentice
Apprentice
thanks I found a local auto salvage that has old parts for trucks.
#50084 09/16/2005 6:21 PM
Too bad you are not nearby as I have 9 axle shafts for that era. What you have to look for is wear at the point the seal sits on the shaft as if worn it will leak. As for seals there are two tmanufacturers, one is Chicago Rawhide C/R and the other is National. One is really much beefier than the other (I think it is National) and a better choice.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#50085 09/19/2005 12:33 PM
Apprentice
Apprentice
thanks again for the help.
