| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50078 09/13/2005 3:39 AM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I have a 56 chevy with a broke axle. It is the original 10 bolt rear end. Can someone tell me where to get parts for it. I need the one axle, seals and bearings. | | |
#50079 09/13/2005 3:48 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Any parts truck from the 50s and maybe earlier will work. Make sure you get the one from the same side. They are different lengths on the other side. | | |
#50080 09/13/2005 10:07 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The seals & bearings can be purchased new at any parts store. They may not be in stock but they get shipments every day from the warehouse. Post an ad on the parts wanted. I,m shure many stovebolters have some old rear ends around. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50081 09/15/2005 4:32 PM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | | | |
#50082 09/15/2005 8:41 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | kevint.... thier is a gentleman that lives in Deford that probably has the parts You need ...If You want his contact info, email me and I will send it to You..
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#50083 09/16/2005 2:39 AM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | thanks I found a local auto salvage that has old parts for trucks. | | |
#50084 09/16/2005 6:21 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Too bad you are not nearby as I have 9 axle shafts for that era. What you have to look for is wear at the point the seal sits on the shaft as if worn it will leak. As for seals there are two tmanufacturers, one is Chicago Rawhide C/R and the other is National. One is really much beefier than the other (I think it is National) and a better choice. | | |
#50085 09/19/2005 12:33 PM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | thanks again for the help.
Kevin | | |
