0 members (), 153 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#5002 05/22/2002 1:53 AM
Junior Member
Junior Member
hello all,
i came across this old chevy military 1 1/2 or 2 ton 4x4... what kind of transfer case was installed? its hard to tell what year exactly, all that is left are the fenders and frame/running gear...
#5003 05/22/2002 10:41 AM
Don't know, BUT, if this is WW2 or Korean time truck, bet it had a hydramatic auto trans and tall shift tower into cab and maybe even a multi-speed second trans. Go to the Futureliner site at maybe www.futureliner.com or www.futurliner.com w/out the E in it. It has a military driveline in the old "bus" unit built around late 30's. There are sites on line dealing with just army vehicles, do a search and find/ask those guys!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
My dad and I used to have a '42 Chevy military 1 1/2 ton 4x4, and it had a manual transmission (engine and transmission were out of a '52 GMC 6x6, but the original driveline was included, and it was also manual). Don't remember what kind of transfer case was in there, but it had some enormous knuckles on the front axle.
1954 GMC De Luxe COE
T-case is most likely Spicer or rockwell.Keep looking and you will find
#5006 05/23/2002 12:23 AM
The transfer case in the WW2 and Korean vintage were made by GM (at least the ones that I own) I'd bet that the earlier ones were also by GM.
Jason
Junior Member
Junior Member
ok, dumd question#2
where on thetransfer case do i look for the numbers.. i know where on or about to look on the 203,205, 208,241, all the new stuff..
thanks for all the help so far!!
