0 members (), 75 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Hey All, I have been searching for a long time for some 4.10 gears for my daily driver 48-3/4 ton truck. I finally found a set thanks to fellow bolter Tyler. He had a set he wasnt using and I had some spare parts I wasnt using so we traded. The best part was that my brother was able to deliver the parts each way and I didnt have to pay shipping. I had a chance to get the new carrier in yesterday and WOW what a difference. The engine is so quiet I may need to invest in a sound system now. I am really looking forward to the improved gas mileage, even if its only 1 or 2 mpg. I highly recommend the swap if you can find the carrier. I still seem to have plenty of power, even with my worn out 235.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
Congrats Ralph! I know you have been looking for those gears for a while.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
[is jealous]
Lucky dog.
Of course, It would help (I suppose) if I had my truck roadworthy...
Lack of brakes is a big deal.
At least, it is to the sheriff.
grin
Hi oldtmy48! I have a 49 3/4 ton that I want to do the same to. They are geared so low, that after you shift into 4th, you need one more gear! I have a question of you. Now since you have the higher rear end, how's it's take off power from a stop, in second?
Thanks!
KT
1949 3/4 ton Chevy
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
OldMy, I know what you mean!
kthomas, I thought I might lug down when I started in 2nd (out of 4) with my 4.10 gears but no problem whatsoever.
Thanks Wally!
KT
1949 3/4 ton Chevy
What did the new gears come out of?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Hey All, Thanks for the responses. KThomas, It starts fine in second. My clutch is about gone from a rear main seal leak so I have mostly been using low to start in. The Bolter that I got the gears from, got them from a wrecking yard and they told him it was out of a 67 - 72, 3/4 ton van. The ring gear is stamped 4.10 so there is no question. I have seen several of the early 60's 3/4 ton trucks have the same rear axle, but all the ones I have found have the 4.57 gears. I know that they are out there, just keep looking. I am going to keep looking for another for my 51, 3/4 ton truck for when I get it roadworthy.
Ralph
48 Chevy 3600 w/235
