5 members (Otto Skorzeny, KEVINSKI, Hanks custodian, SmalltownTRKGuy, 1 invisible), 69 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#500152 01/31/2009 11:40 PM
anybody have any opinions.good,bad ? saw it in 3/8 in a 25' coil at a swap meet for $20.00 a roll.was thinkin a roll would do my fuel and transmission lines.any experiences?.pros ,cons vs.steel ?..............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Dave, I bought some a few years ago, and have use it for my fuel line, without any porblem. I used the blue AN fittings to connect to the fuel pump and carb.
Bryan Bauman
Would sure be easier to bend.
~Jim
I've used 3/8" stainless steel fuel lines, It's tough to work with and you need a really good bender.
I've seen some aluminum fuel lines used, and I'm not sure I like the idea but there is probably nothing wrong with them. I would use plenty of rubber cushioned clips to keep it from flopping around and rubbing on stuff.
I have some more 3/8" fuel lines to make, I'll try some copper nickel lines this time, also called cupronickel and Cunifer.
Do a search on ebay UK, that's where I've seen the best prices even with shipping over here.
Here's some more about it, and my thoughts:
https://www.stovebolt.com/ubbthread...g&topic=0&Search=true#Post487333
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Aluminum works fine, been using it for years. A new coil wasnt much more than $20 at my local carquest.
Big Chevy- i agree,figured it would flare easy as well
Grigg -i think your right about keeping it in place,cuchion clips would definatley be a must
i'll do some more checking this might be the way to go......................dave
1949 Chevrolet 3100
It has been used on aircraft forever. Like it was mentioned be sure to use plenty of adel or cushioned clamps to prevent damage by vibration or rubbing on other things.
Old chevy
Aluminum and copper are fine for even E10 fuels. However, neither are recommended for the E85 stuff! Be sure to use the E10 rated blue-lined flexible rubber lines as vibration isolators. We've noted that the non-E10 rated lines go soft when subjected to E10 blended fuel. It might be a seemingly insignificant detail until your ride goes up in smoke.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
that would suck alot..................dave
1949 Chevrolet 3100
