| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | anybody have any opinions.good,bad ? saw it in 3/8 in a 25' coil at a swap meet for $20.00 a roll.was thinkin a roll would do my fuel and transmission lines.any experiences?.pros ,cons vs.steel ?..............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | Dave, I bought some a few years ago, and have use it for my fuel line, without any porblem. I used the blue AN fittings to connect to the fuel pump and carb.
Bryan Bauman
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Would sure be easier to bend.
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've used 3/8" stainless steel fuel lines, It's tough to work with and you need a really good bender. I've seen some aluminum fuel lines used, and I'm not sure I like the idea but there is probably nothing wrong with them. I would use plenty of rubber cushioned clips to keep it from flopping around and rubbing on stuff. I have some more 3/8" fuel lines to make, I'll try some copper nickel lines this time, also called cupronickel and Cunifer. Do a search on ebay UK, that's where I've seen the best prices even with shipping over here. Here's some more about it, and my thoughts: https://www.stovebolt.com/ubbthread...g&topic=0&Search=true#Post487333Grigg | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Aluminum works fine, been using it for years. A new coil wasnt much more than $20 at my local carquest.
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | Big Chevy- i agree,figured it would flare easy as well
Grigg -i think your right about keeping it in place,cuchion clips would definatley be a must i'll do some more checking this might be the way to go......................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2009 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 47 | It has been used on aircraft forever. Like it was mentioned be sure to use plenty of adel or cushioned clamps to prevent damage by vibration or rubbing on other things.
Old chevy | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Aluminum and copper are fine for even E10 fuels. However, neither are recommended for the E85 stuff! Be sure to use the E10 rated blue-lined flexible rubber lines as vibration isolators. We've noted that the non-E10 rated lines go soft when subjected to E10 blended fuel. It might be a seemingly insignificant detail until your ride goes up in smoke.
Dave | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | that would suck alot..................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
