2 members (JoergK., TUTS 59),
120
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | I need some pics of the lower outlet to see if its similar to a 37,I am wanting to put a original 3 piece lower hose on my 37 but I have a 54 water pump which has the same angle of the outlet as back to 41 and I want to see some pics of the lower outlet so I can see if a 41-6 lower hose kit will work. A local junkyard has a few but I dont know if the radiators are still in them plus there is probably over a foot of snow in it so if anyone has any pics handy I would appriciate it and I could not find any original radiators on ebay at this time. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Jeff, didn't take these for the Radiator, but see if they help. 41 1.5 ton. Lower hose connected, but not to pump. Radiator, R. Side From front angle Hope this helps? -Michael | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Jeff I don't have a pic of it but the lower connection on my '46 is oval, curves slightly to the outside and is 2" OD wide X 1 1/8" OD tall. I hope thats the info your looking for
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Since the sun was out and it was a little warmer I hit the junkyard that has a few 41-6s and I think I can use a 41-6 3 piece lower hose kit on my 37 with the 54 water pump as the lower radiator outlet looks similar to a 37,I did look for other parts and found the generator brackets but could not find a horn that looked good enough due to the hoods being open for many years. I did find a 54 235 intake I will grab too because on the 57 intake the carb is angled too much and with a 54 intake the carb will sit more level then with the 57 intake. Jeff | | |
