1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
I need some pics of the lower outlet to see if its similar to a 37,I am wanting to put a original 3 piece lower hose on my 37 but I have a 54 water pump which has the same angle of the outlet as back to 41 and I want to see some pics of the lower outlet so I can see if a 41-6 lower hose kit will work. A local junkyard has a few but I dont know if the radiators are still in them plus there is probably over a foot of snow in it so if anyone has any pics handy I would appriciate it and I could not find any original radiators on ebay at this time.
Jeff,
didn't take these for the Radiator, but see if they help. 41 1.5 ton. Lower hose connected, but not to pump.
Radiator, R. Side
From front angle
Hope this helps?
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Jeff I don't have a pic of it but the lower connection on my '46 is oval, curves slightly to the outside and is 2" OD wide X 1 1/8" OD tall. I hope thats the info your looking for
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
Since the sun was out and it was a little warmer I hit the junkyard that has a few 41-6s and I think I can use a 41-6 3 piece lower hose kit on my 37 with the 54 water pump as the lower radiator outlet looks similar to a 37,I did look for other parts and found the generator brackets but could not find a horn that looked good enough due to the hoods being open for many years. I did find a 54 235 intake I will grab too because on the 57 intake the carb is angled too much and with a 54 intake the carb will sit more level then with the 57 intake. Jeff
