| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Years back I re-wired my stock 49 using connectors, wires and the schematic in the shop manual. I went wire to wire and it was pretty simple and works perfectly. Now I am thinking of going with one of the big name harness kits because my ignition and headlight switches are getting old and I really don't like the squirrel's nest of wires under the fuse box. It would be nice to have new components like switches and real fuses. Maybe I have a mental block but when I read how easy it is to install one I these kits I start asking myself questions and the one which comes to mind is how does the juice get to the new fuse box? I know its a dumb question but I assume it comes from the same source as the original. And with my add-on turn signals will I have to do some complicated rewiring? Thanks | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Blu, On my Ron Francis kit the main power lead from the starter to the fuse panel was included along with the 1 wire alternator set up wich I requested. Every wire was included in the kit along with new headlight plugs and a connector to hook to a 70's chevy steering column including the brake light switch. Best thing I did was call there customer service an told them exactly what i wanted to do and what steering column, alternator and stuff like that I was using and had NO PROBS. Everything was in the kit. Tim
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Tim. This truck is all stock except for the turn signals and a 12 volt system. I do not plan on changing the steering column and was hoping the brake light switch and turn signal wiring in a kit would take that into consideration. | | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | I agree with SW-Radial. I installed a Ron Francis harness and it was a snap! Their tech assistance is top notch if you have any problems. I had never done anything like that before and everything works. I had also told them everything I wanted to do and they made the kit. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I also agree with fasteddie, the customer service dept. at Ron Francis is TOP NOTCH! Tim | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | However does anyone know of a company that would replicate the original wiring in a 49 without having to go to a later model column, alternator and does consider the aftermarket turn signals? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | As I understand it Painless and Ezwire both have model specific kits. Mine was from American Auto Wire and I choose the kit that allowed me to place the fuse panel wherever I wanted it. All wires were about 8 feet longer than needed. I would suggest this kit for anyone that wanted to customize their wiring.
~Jim
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | However does anyone know of a company that would replicate the original wiring in a 49 without having to go to a later model column, alternator and does consider the aftermarket turn signals? YNZ
| | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | Try Rhode Island Wiring Service. They make harness for the restorers. You can always build your own-- it ain't that hard if you just take your time. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have done my own but years ago and now, as I wrote at the outset, I am concerned about the original switches and the mass of wires under the fusebox. | | |
