| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | TH350, stock pan and converter.how much fluid should it take to fill ? before installing a stock converter how much fluid should i put in it ? thanks..................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Don't worry about pre-filling the torque converter.
Put 4 quarts in, start the engine, add 3 more, then add 1/2 at a time (checking fluid level each 1/2 quart)
Then shift manually into each gear PRNDL-LDNRP. Check the fluid level again. It's better to leave it a little low(at the add line) than to over-fill it.
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | It won't hurt to dump in a quart or two in the converter, but the pump will fill it as soon as the engine starts. With a small cooler, you should be in the 11 quart range if the transmission was dry with a dry converter. Start with four and go from there. Be sure to let the fill tube drain a few minutes before checking. Joe
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi David, according to my manual.
A Th350 from 'bone' dry holds 10 quarts.
It wont hurt to put in 7/8 and as 54TOW says,top up 'till
you reach the correct level. It may also vary depending on cooler/length of lines and pan size. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | thanks guys....................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
