5 members (ShopRag, kurbside bolter, Ponchogl, cmayna, 1955 1 Series), 107 guests, and 4 robots.
Topics128,268
Posts1,058,375
Members48,485
Having trouble trying to figure out how to separate the engine from the transmission. Does the bell housing need to come out with the fly wheel?
how do you remove the bell.just the 4 bolts?
It's been a while but I believe you can remove it with the bolts that connect it to the engine block. I may be wrong but I believe it would be easier if you just unbolted it from the tranny along with the clutch arm and pull it with the engine. I assume you have already pulled the radiator.
~Jim
Riding in the Passing Lane
You have to pull the bell housing with the engine. Then remove the clutch & flywheel through the opening under the bell housing. Then you can remove the bell housing. There are 2 bolts behind the flywheel.
1972 Chevy c10 Cheyenne Super
I kinda guessed.Idid what Wrenchbender said.the engine was already out.Thanks guys.
