1 members (1 invisible),
100
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 8 New Guy | | New Guy Joined: Mar 2006 Posts: 8 | Having trouble trying to figure out how to separate the engine from the transmission. Does the bell housing need to come out with the fly wheel? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | how do you remove the bell.just the 4 bolts? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It's been a while but I believe you can remove it with the bolts that connect it to the engine block. I may be wrong but I believe it would be easier if you just unbolted it from the tranny along with the clutch arm and pull it with the engine. I assume you have already pulled the radiator.
~Jim
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have to pull the bell housing with the engine. Then remove the clutch & flywheel through the opening under the bell housing. Then you can remove the bell housing. There are 2 bolts behind the flywheel. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | I kinda guessed.Idid what Wrenchbender said.the engine was already out.Thanks guys. | | |
