| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 8 New Guy | | New Guy Joined: Oct 2008 Posts: 8 | Hi gang, I searched the previous posts, but haven't found one on removing the rear shackle bushings on an AD '51 1/2 ton. Can I rent a tool from the local auto store to press them out, or will hammering using an expendable socket get them out without damaging the leaf spring bracket? Thanks in advance | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I used a hammer to get mine out, and soaked it with PB Blaster. I've also heard that you could carefully saw out a section of it to make it easier to get out. I think I used a socket when I hammered mine out. You might also be able to use the threaded pin that goes through the bushing if it fit good, wasn't rusted, and you were replacing it. Samantha
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | You can pull out the bushings using a socket and a long 1/2'' bolt and nut with washer. Installation is the reverse procedure. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | This shackle bushing had a bent pin jammed in it. It's been the toughest shackle bushing I've come across so far. The puller is a generic setup that you should be able to rent. Puller setup on '54 2-ton shackle bushing. Bushing Push 1 The adjustable wrenches are a 16" and an 18". Bushing Push 2 I've been advised that using chrome plated sockets as shown in this picture is not safe. I should have used impact sockets that are less prone to shattering. Bushing Push 3 Results: Puller and bushing.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used the ACME screw from a 3-jaw puller along with the jaw nut to pull mine out- I stripped out a grade 8 bolt and nut trying to do it that way. The acme screw threads are much stronger.
I ended up removing one of the spring eye bushings by drilling through the rubber part with the biggest drill bit I could find, and then using one of the little air reciprocating sheetmetal body saws you can get at Harbor Freight to saw a slot in the outer bushing shell. Those things are like a tiny sawzall and they work great. Before I got one of those I would find the right drill bit diameter so I could drill between the inner and outer shell and try to get it centered to trough out the metal, but thats really hard to do well.
