3 members (klhansen, tricordati, Pre '68 Dave), 91 guests, and 2 robots.
Topics128,096
Posts1,056,477
Members48,444
I thought this looked like a cheap simple solution to run a 6 volt radio on a 12 volt system. http://www.ford-trucks.com/article/article.php?id=040
I think this is a nice design piece that somebody has worked out. It apparently can supply 10 Amps.
thanks, Neilroy
1951 1 Ton Completed
Good info, I've been looking for a setup like this to build. Thanks!
1960 GMC Panel w/ 305 V6, 4 Speed TV Repair Van "The Monitor Lizard"
1961 Chevy Apache 20 283, 4 Speed, Hydrovac
www.picturetrail.com/starchief
Yes, that is a very nicely done design and an excellent article. Adding the power transistor gives you 10a. The whole shebang shouldn't cost any more than a MacDonald’s happy meal.
I appreciate the effort these guy put into things like this and then they offer it freely to the membership. Definitely good people.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I built this and it works just fine. The total price was about $20 but I also got a 10 pack of the diodes and some heat sink compound. That is if you can fine a heat sink out of something. I used one off of an old dead 60's am radio.
Hey Neil, ya got a couple of pic of that
board/unit that ya made? Where did you
find the power transistor?
Denny G
Denny G
Sandwich, IL
I will shoot a photo when my wife gets back from her nephew's wedding with my camera. I used an NTE181 power transistor. It crossed to the 2N5881 even though it doesn't look like it will handle as much current. http://www.nteinc.com/specs/100to199/pdf/nte180.pdf It seems to work fine so far and was all I could find locally. If it passes away I will order the 2N5881 online.
That transistor orta work just fine in that application. The only retail outlet store where you can walk into and buy something off the shelf is Rat Shack and they are removing more and more inventory daily. The largest power transistor they list now can only handle about a third of that current.
I buy mail order from Mouser but hate to place a small order and usually end up buying ten times what I need just to justify the UPS shipping costs.
Denny G
Denny G
Sandwich, IL
A good place for the DIY crowd to buy electronic parts is www.digikey.com
They don't have a minimum for small orders, quick ship, and good prices. I use them all the time for this type of thing.
Paul
I have used Digikey too. They carry a lot of good electronics.
Moderated by  truckernix
