5 members (Steelonsteel, 2-Ton, Cosmo, 32Fordpuchoptop, farmallb), 150 guests, and 2 robots.
Topics128,089
Posts1,055,991
Members48,430
#497631 01/26/2009 3:31 AM
What on my engine needs to be replaced, or changed if I have a generator and I want to install an alternator?
56 stepside 3/4 ton longbed
alot of the vendors (like lmc truck, classic parts of America and Jim Carters) carry a bracket set for changing out the generator to an alternator. That is about all you need. Aside from some wiring (for 3 wire alternators), there isn't much to change out.
You may need to change the pulley on the alternator to fit your belt width. I found that I could swap the pulleys between my generator and my alternator (Delco 10si) when I was doing my 216. Just make sure the fan doesn't hit.
Paint & Body Shop moderator
