| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | What on my engine needs to be replaced, or changed if I have a generator and I want to install an alternator?
56 stepside 3/4 ton longbed
| | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | alot of the vendors (like lmc truck, classic parts of America and Jim Carters) carry a bracket set for changing out the generator to an alternator. That is about all you need. Aside from some wiring (for 3 wire alternators), there isn't much to change out. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You may need to change the pulley on the alternator to fit your belt width. I found that I could swap the pulleys between my generator and my alternator (Delco 10si) when I was doing my 216. Just make sure the fan doesn't hit.
