| | | Forums66 Topics128,196 Posts1,057,385 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | im so close i can taste it its almost done so i got the windows back in put the inside anti rattle strip on the door found out it goes on the inside window trim instead next finally got the speedo out setting at home getting ready for new chrome and face decals start pring the needle off instead the shaft snaps leaving an 1/8 inch sticking out thinking i can glue4 a plastic tube over it and mount needle on it is there any other fix besides finding another speedo next week ill be cruising my truck 2 years and a lot of elbo..need help sending pictures whats the easiest way..i could have never finished this truck without the help on this site | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | well it worked after two tryes i jb welded a w-d tube onto the shaft then cut to length worked perfect jbed needle on how do you send pictures | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | im so close i can taste it its almost done so i got the windows back in put the inside anti rattle strip on the door found out it goes on the inside window trim instead next finaly got the speedo out setting at home getting ready for new chrome and face decals start pring the needle off instead the shaft snaps leaving an 1/8 inch sticking out thinking i can glue4 a plastic tube over it and mount needle on it is there any other fix besides finding another speedo next week ill be cruising my truck 2 years and a lot of elbo..need help sendin pictures whats the easyest way..i could have never finished this truck without the help on this site WOW, that's got to be the longest sentence I've ever read. Also, what year truck are we working on? Scott | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | To post photos go to one of the free services like webshots.com and upload your photos. Go to the photo on that site and copy the address and paste it to your post. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | shes a 1952 3600 all stock except 235 motor now i need white walls | | |
