| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49680 08/29/2005 12:31 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Was down at the local Sunday morning meeting place this a.m. and a guy approached me with an Offy dual intake for a 216/235.
Looks like it could use some polishing and needs cleaned up, but didn't seem in bad shape at all.
Anyone know what it might be worth, or have any interest? He thought a couple of hundred??? | | |
#49681 08/29/2005 12:34 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I think you can get them for a little less then that........I had one that came with my truck but I never did use it,, brand new.. I gave it to one of our bolters because I did not think I would ever use it...........it was an offy...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#49682 08/29/2005 12:40 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Thanks Joker. That at least gives me an idea.
I don't really have any interest in it, but thought I would see what it might be worth, and if anyone else had any interest. | | |
#49683 08/29/2005 12:47 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I would be interested, but Patrick's has em for about $190 new. Is it an earlier, cooler design that the new ones? Does it have the heat plate underneath that bolts to the exhaust? | | |
#49684 08/29/2005 12:55 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Bob, I don't know that much about them. Where might I see a picture of one to see how it compares? This one was ribbed aluminum, (I believe)and looked like it would polish up pretty nicely.
It was designed to bolt directly to the exhaust, just like the stock intake.
I can get you in touch with the guy if you want. Or better yet, come up one of these Sunday mornings, and I'll hook you up with him directly.
I don't think he knows what it's worth, he just threw out that number to see what he might catch.
Let me know | | |
#49685 08/29/2005 1:45 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Here's a pick of the Offy Intake Offy Dual Intake | | |
#49686 08/29/2005 4:14 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Bob, That's how I remember this one looking. | | |
#49687 08/29/2005 4:17 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | For what it's worth, I'm sure you guys know that there is a difference between the 216 and the 235 intake. The one pictured looks like a 235 Offenhauser intake. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#49688 08/29/2005 4:39 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | 6cly, I knew they were different, but didn't know there was enough difference in the 216 & the 235 intake to tell from a photo. But, yes, it's a 235 intake in the photo. I couldn't find a pic of the 216 intake. Is the diff the size of the intake bores, the intake length, or both? | | |
#49689 08/29/2005 5:22 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I thought the pre-1954 (up to 53) 216 and 235's were the same and after that they early ones were different from the later ones. I was under the impression that this was the result of the change in the oiling system so the newer heads have the intake ports a smidge further apart?
#49690 08/30/2005 3:07 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | There are three differences. The ports on a 216 intake are smaller. The carb bases on a 216 are smaller. The spot on the bottom of the 216 intake where it mates up to an exhaust manifold is configured different than the spot on the 235. They look the same at a quick glance, but they are different and require a different gasket. The first two differences can be made to work for a 235. The ports can be machined out to fit a 235 head with no problems. The smaller base 216 carbs will work fine on a 235 and, in fact, are preferred by some. But the maching of the intake and the exhaust is not possible and that usually spells trouble, unless you use a 216 exhaust manifold, or go with Fenton, or some other brand of headers, that do not require the mating to the intake. I am running an Edelbrock 216 intake on an 848 - 235 head with Fenton headers. I had the ports machined out and I am running two small base Pontiac Rochester carbs. Everything works fine!! Hope this helps! Joe
