1 members (homer52), 88 guests, and 3 robots.
Topics128,127
Posts1,056,678
Members48,452
Did search on this, didn't find solid answer.
Can somebody verify for me that the original bolts holding the rear motor mounts to the frame cross member on the 216 were in fact:
7/16-fine thread, with a cotter pin hole, and a matching, "castelated" nut? And what washers where? Lock washers, I'm guessing . . .
THANKS!!! smile
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Perhaps oddly, mine had a regular nut with the cotter pin and I have no reason to believe it is not original. Heres a picture. The bolt has a "P" on the head. The bolt and lockwasher were coated with black oxide and the nut and pin were bare.
kingisomer,
Thanks! That helps a lot. My bolt is actually about 3.5 inches long, but looks identical in all other respects. I suspect the difference in length is that mine is on a 1.5-ton chassis. Prob. bigger truck with a bigger frame requires a longer bolt.
I found two regular nuts in my "pile",but just assumed with the cotter pin hole it would use a castle nut. I guess that's not necessary! I didn't know until I started looking for them, that 7/16th bolts are such an odd size. (can't find 'em in the local hardware store, or even Home Depot/Lowes). Glad I found mine!
-Michael
Kingisomer, mine look exactly like yours including the "P" and standard nut
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
