5 members (R&S 51 GMC, Guitplayer, Wayne67vert, Lightholder's Dad, Otto Skorzeny), 161 guests, and 3 robots.
Topics128,125
Posts1,056,338
Members48,440
Hi,
I have a chevy 51 1/2 ton and I need to change the front wheel bearings. On americanclassic
I found upgrade conversion kit, BR2600.
Is it better than the original bearings ? Who tried ?
Does it match without problem or can I do some modifications ? (I don't use brake disk).
Kind regards.
Steve
I swapped to roller bearings when I went to discs because it was recommended. With standard brakes the ball bearings would probably last 100,000 miles or more. I'd consider the price difference.
Riding in the Passing Lane
If you need to buy new wheel bearings it,s best to go with the roller conversions. If your bearings are OK I would reuse them. They are no broblem to change over.
1972 Chevy c10 Cheyenne Super
Hi everybody,
Thank's a lot for your informations.
Steve
1 Offline
I have managed 480,000 miles on my original ball bearings. I don't think there is anything wrong with their design however I have a set of roller bearings to fit my car and I figured if my originals ever wore out I would change them.
As long as you know which type you have and adjust them properly they are both excellent. Design wise the roller bearings should be more efficient. It's up to you you pays your money and makes your choice. Just make sure to adjust them properly.
Series 6-30B Pontiac
Assembled in Regina Saskatchewan
June 6, 1930.
Happy Hobbying
1911 commer- Could you, or anyone else, post the number stamped on the bearing in the kit you've got together with the year it is supposed to fit?
The people that sell those expensive bearing mark them up quite a bit. With the part number you can go to napa and they'll put it in the computer and sell you the same piece for a less.
Thanks!
PS-(I already converted my '51 to the newer style bearings, when I put in the disc brakes, and paid full price for 'em)
